If reentrant debugging were handled the same on the RTOS as in Windows.
Opening each instance of the reentrant VI would show you the "Clone #" and allow the developer to see data in each instance seperately.
This would make my life so much easier!
Then you should register your vote by clicking the Kudo star!
