Author: CharlotteN (NI)
Changes a Bundle or Bundle By Name to the Unbundle function of the appropriate type and vice versa. So selecting this option...
..... produces this:
It can work on a selection of bundlers or unbundlers but not a mixture of both. All inputs/outputs in a Named Bundler/Unbundler will revert to the first element in the cluster. This is something I would like to change if I find time.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Just curious if you had time to fix the naming issue?
Hi Ian, it has been a long time since I looked at this plug-in I must admit. What issue is happening with regards to naming?
Hi Charlotte,
Just tried this plugin today and it didn't work first time.
I opened the LLB and each of the VIs, and it looks like some path reference issue was bugging the plugin.
After re-saving all VIs, then it worked.
Just to inform, I don't really know if it just happened to me.
Cheers,
