This Plugin creates a cluster from a group of controls or constants.
Creating a cluster is a non-trivial task in LabVIEW, and can be somewhat tedious. This automates that by adding a right-click option for combining several controls in to one cluster.
LabVIEW 2015 or higher
1. Place the desired controls, indicators, or constants.
2. Select all, then right click on the group and select "Change to Cluster".
3. Enjoy your new cluster.
Currently, items are added in the order that they appear vertically on the front panel or block diagram.
