LabVIEW Shortcut Menu Plug-Ins
Diagram Disable Toggle.llb
Author: ConnerP
Edit time plugin
This plugin puts an option at the top of the pop-up menu for either disabling or enabling a frame of a diagram disable structure, depending on it's current state. Every time when using a DDS for debugging purposes, I felt I had to search "forever" in the list of options, of which 99% of the time I only wanted to disable or enable the frame. This makes sure it is always right at the top, where I need it.
Contributors
