LabVIEW Shortcut Menu Plug-Ins
Remove 'Replace with Stacked Sequence' Menu Item
Author: Darren (NI)
This plugin removes the Replace with Stacked Sequence menu item from the Flat Sequence right-click menu. Yup, that's all it does. You're welcome.
Attachement is saved in LabVIEW 2015. For install instructions, go here.
Comments
Craig_
NI Employee (retired)
on
A+ plugin
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
bsvare
Member
Member
on
Best plug-in I've ever seen, bravo Darren!
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
AristosQueue (NI)
on
Best you've...?!?! You're telling me *that's* all it takes to earn user love?! I've clearly been aiming too high!
Contributors
