This plugin removes "Create Wire Branch" and "Delete Wire Branch" from the right-click menu for wires.
Great idea for a shortcut (those menu items are worthless), but it looks like you have the code that modifies the menu commented out?
Good catch. I forgot to remove the disable after needing to see the items to get the text right in my post ![]()
Great find. Using it ! Should be part of LV. 5/5
