LabVIEW Team Indonesia
how to connect the output of fuzzy logic controller to the DAQ to generate the analog output voltage signal and how to feed the output of DAQ as the input of fuzzy controller
Dear friends,
             I am trying to implement a fuzzy logic controller. I built MISO type FLC. One input is set point which i will numerically control and the other input should be acquired as analog voltage signal value of my sensor which i acquired through DAQ. The output of the fuzzy controller is to be connected with DAQ and the value should be generated as voltage signal through DAQ.
I have two queries??
1. how to feed the acquired analog voltage signal value of sensor as one input to the fuzzy controller
2. how to generate the output of fuzzy controller as a voltage signal through DAQ
     I hereby attached my .vi file. please go through it and give me an solution for this problem
thanks and regards
chandrasekar
09597748312
mds14m002@iiitdm.ac.in
(3,976 Views)
please approach your NI local support.
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
(3,601 Views)
hi sir,
   thanks for your reply...Since my SSP was expired they are not helping me....
(3,601 Views)
ah that is too bad. I am sorry that this forum is focusing in Indonesian language. Please use the general forum at ni.com
(3,601 Views)
