LabVIEW Team Indonesia
please help
Dear friend
Thank you for your interaction with my questions
I tried to made a project to measure the vibration signal and acoustic emission for a rotary machine as follows
I use a sensor to measure the vibration through a DAQ 9234 I use the IEPE through MAX
and another sensor to measure the acoustic emission through a DAQ 6251
Initially tried to collect the raw data ​​by using simple scheme work by the LapView program. I do not know whether this Planned is true or not, or the values ​​obtained from Planned is accurate or not.
Another problem is the signal that obtained is have a high noise ratio, so I want to improve the signal-to-noise ratio (SNR) by LabVIEW program
If you want I can send to you the planned to give me your opinion?
thanks
Yasir
Message 11 of 12
(273 Views)
Hello my friend,
Sure, you can send it and we will give our opinion
Cheerz,
Suryo
Message 12 of 12
(273 Views)
