This example project uses LabVIEW Web Services to publish and stream images over internet.
Project content
Thanks: https://stackoverflow.com/questions/20877813/auto-refresh-images-in-html
Ref1: https://en.wikipedia.org/wiki/Motion_JPEG#M-JPEG_over_HTTP
Ref2: http://www.ietf.org/rfc/rfc2616.txt
OBS: MJPEG over HTTP is not supported by Internet Explorer natively, it is required to install an add-on, at least when I tested it. I didn’t investigate much though.
How to run
1. Open the project
2. Right-click on “myWebService” and select “Start”
3. Right-click in on of methods, e.g. MJPEG.vi and select “Show URL Method…”
4. Copy this URL in an Internet Browser
Final considerations
Dependencies: NI Vision Acquisition Software
Hardware tested: Laptop with Webcam, cRIO-9068 with Basler USB3.0 camera and sbRIO-9651 + Dev Kit with Basler USB3.0 camera
Hi.
Thank you so much for sharing this. It has been extremelly useful for me, and also really easy to use. It works like a charm.
How difficult would it be to deploy this as a source distribution instead of using it as a LabView project? For my needs, I would need to be able to use the startup.vi outside the project.
Hi, tried to run the example, but web service refused to start, giving error code 67003. Disabling SSE2 did not solve the problem. Please advice. Thanks.
Same thing happens to me, Noriker. I can run it in debug mode (port 8001), but not in production (port 8080).
