Hello!
I am not familiar with English, so the meaning may not be communicated well.
I want to add a URL image and a string to the cluster so that the string can be printed on top of the URL image.
How can I configure the css?
My development environment
NXG 5.0
Windows Pro 64bit
Hi Jively,
Thanks for getting in touch. One thing to note is that this post was created as a Document. Documents are useful to share example code and tutorials. For asking questions you should instead make a Discussion post. In the future you may get more responses by posting LabVIEW NXG WebVI questions in the LabVIEW discussion forum: https://forums.ni.com/t5/LabVIEW/bd-p/170
If the cluster layout mode is configured to None then you can position a String control inside of a cluster on top of a URL Image like the following:
So inside of a Cluster control you can position a String control on top of a URL Image control without using CSS. Is this what you are trying to achieve?
