LabVIEW Web Development Discussions
Pass data from Main VI to HTTP Method VI
Hi guys,
I'm fairly new to Web Service and HTTP.
Can anyone tell me what's a good method to transfer data from my Main VI to the HTTP Method VI? In a project I'm working on, I enqueued 12 bytes of data into a Queue, which is later dequeued at the HTTP Method, which is then transferred over web service.
Is it advisable to use Queue?
(5,162 Views)
Not sure if there is exactly a right answer to this.  What goes for standard LV goes for LV using web services.  You can use named queues, global variables, functional global variables, etc etc.  Queues are a great way to pass data - you know that the main VI is no longer active when the queue throws an error and you can have your app respond with the appropriate http response code.  In a large application that I am building, I have the main app return data via a DVR that is wrapped in an FGV  Works for me.
But, as with all software engineering, there is not exactly one right answer...
Cheers, cirrus
(4,951 Views)
