LabVIEW Web UI Builder and Data Dashboard
Calling a web vi which has a while loop inside ?
Hello everyone
I am new to this Labview web ui
I developed a small vi which has while loop and inside it a event structure. this event structure send the data to output string when boolean value is changed .
When i called this vi in labview web vi this is not working when boolean value is changed . what might be the problem
(6,213 Views)
Do you want to use this VI as a webservice?
If this is the case you don't need to use a while and an event structure...
p.
(6,174 Views)
