LabVIEW Web UI Builder and Data Dashboard
Custom controls/indicators
Hi!
Is it possible to use custom controls/indicators?
Or to "customize" those provided?
e.g. change the background image of a gauge...
Marco
(6,806 Views)
Unfortunately the answer is "no" for this version of Data Dashboard (the only things you can customize are the maximum and minimum values of the gauge and chart). But it's definitely something we're looking to include in the future!
Out of curiosity, what's your use case? Are you trying to differentiate between controls, build a custom look-and-feel, or something else?
Edit: Are you asking about Data Dashboard or Web UI Builder? The latter does give you some more customization options.
(6,798 Views)
HI!
I'm tryng to customize a web interface built with Web UI Builder and want to include custom indicators.
I was playing with transparency  to place some images under the provided controls and had some problems.
Seems that "system" skin is better when you need transparency....
Thanks for replying,
Marco
(6,786 Views)
