LabVIEW Web UI Builder and Data Dashboard
LVWUI Errors
I've got a bunch of error messages attached (rerrors esulting in the recommendation to save everything and restart LabVIEW WebUI...) which oftentime happen when I switch from one tab to the next while editing a tab control or ctrl-dragging a control to copy it...
Their frequency is a bit frustrating, I should add.
X.
(6,972 Views)
Hi X,
R&D would like to take a look at the VI that's demonstrating this behavior. Our terms and conditions state that we will not access your cloud-stored VIs or violate the privacy of your cloud storage. Do you mind exporting the project and attaching it to this thread?
You can export a project by clicking on the Manage Projects button in the Project tab in the ribbon. You select a project in the list and then click on the export link near the bottom of the dialog. It will create a zip file of your project and ask you where to save it.
Sorry for the inconvenience.
Mike
(6,967 Views)
What about I send it to your email address?
(6,962 Views)
Hi X,
That would be fine.
(6,958 Views)
