LabVIEW Web UI Builder and Data Dashboard
Problem with Web Builder and MySQL connection
I've created a web service VI (see image attached) to communicate my Web Builder app with a MySQL database. The problem is that I get nothing on my output indicators when calling the web service VI.
Some tests I've done:
1) This web service VI works perfectly (I mean indicators 'valor', 'status' and 'data_hora' give the desired output) when the VI executed directly through LabVIEW. So mySQL connection and my VI are OK...
2) I'm know my web service VI has been correctly built and deployed because indicators give me some value if I link something to them other than my SQL output
     (for example: if I put a constant string 'Hello' on the indicator 'valor' I get 'Hello' when calling the web service VI)
I suppose database connectivity toolkit is not supported when a VI is built into a web service VI. In my case, toolkit VIs are inside subVIs 'start', 'exec 2d' and 'stop' showed in the attached image.
Any idea?
Marcelo
(11,726 Views)
I think it's easy to understand without subVIs. The full code of my web service VI is as follows:
An additional information: as error occurs on the output of the first VI of the Database Connectivity Toolkit when my web service is executed as a deployed web service VI. But when executing it from LabVIEW, no error occurs.
(11,719 Views)
First I would like to know which labview version are you using and what the error number ocours.
I can say also that by creating an executable, is necessary to include a file in your application. The link below will show you how to do this:
http://digital.ni.com/public.nsf/allkb/FCCCBC6B519CEC2E86256C95007E8FA9
Thanks for your contact and I hope this help you. Success in your application.
Wesley Rocha
National Instruments Brazil
www.ni.com/suporte
Wesley Rocha
Application Engineer
Visite a nossa comunidade em PORTUGUÊS!!!
Certified-LabVIEW-Associate-Dev
(11,665 Views)
Accepted by topic author gracietti
I'm using LabVIEW 2001 Wesley, but I solved my problem.
It was just a MySQL database source problem: I just had to add my DB info through C:\Windows\SysWOW64\odbcad32.exe.
Marcelo
(11,606 Views)
