LabVIEW Web UI Builder and Data Dashboard
dashboard string multi-line iOS
I fail to display text on multiple lines on an Ipad
but that's ok on android
the line breaks are not taken into account on iOS
there must be a subtlety?
is what you know this?
Thank you
I have no answer on the french forum Smiley Sad
Message 1 of 8
(14,403 Views)
Is there someone to help me ?
Message 2 of 8
(14,231 Views)
nobody knows Smiley Sad
Message 3 of 8
(13,656 Views)
Is it a bug ?
Message 4 of 8
(13,614 Views)
I found a workaround!
Use a network-shared array of strings instead and assign it to the property "List Items" of a List Box indicator:
Example code here:
Building an array of stringsBuilding an array of stringsthe network-shared variablethe network-shared variableconverting an existing multi-line string into an array of strings (makes use of OpenG's Multi-line String to Array.vi which is part of the OpenG string lilbrary available via OpenG Library on LabVIEW Tools Networkconverting an existing multi-line string into an array of strings (makes use of OpenG's Multi-line String to Array.vi which is part of the OpenG string lilbrary available via OpenG Library on LabVIEW Tools Network
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 5 of 8
(12,420 Views)
thank you,
I'll test it, when it'll was possibleSmiley Happy
Message 6 of 8
(12,385 Views)
there is screen difference between ipad and android tablet, both use different type of operating system, check your code again and did you use </br> line break tag?
Message 7 of 8
(11,251 Views)
Hey Richard,
Thank you for your additional input. As described in the first two posts, thib_fr had no problem with line breaks on Data Dashboard for Android. Only the iOS version was problematic (but a workaround exists, as I described).
I am not sure if your posting is a question or an additional suggestion.
I did not use any html tags on my code (should be <br /> by the way in xhtml, having the slash at the end). I don't own any apple hardware anymore, therefore cannot test if this would make a difference. My gut feeling however is that it does not.
I attached my demo project from a year ago to this posting, could be more handy than the snipped above. Disclaimer: It contains one OpenG VI.
CLADMSD
Message 8 of 8
(11,246 Views)
