LabVIEW Web UI Builder and Data Dashboard
error data dashboard
Good afternoon friends, and had some problems with the mobile application on my tablet. the problem is that after the completion of the project in LabVIEW when I connect to the ip of my pc for tablet gives me this error "connection error invalid. Server can not connect to server check the address and wireles connection and try again" help me please !: smileysad:
(9,065 Views)
Hello Jhonny_2307
I would like to ask you a couple of questions.
Did you run the VI on highlight execution mode?  To see where exactly are you getting the error code?
Warm Regards.
Sigi Darcia
Application Engineer
"everything is achieveable through technology'
(9,014 Views)
Accepted by topic author jhonny_2307
goodnight friend and troubleshoot the data dashboard was my antivirus and had to put my tablet mode superuser (root) thank you anyway for your help !! if you know someone with the same problem that has q Tell root your mobile device and disable the antivirus. greetings!
(8,996 Views)
