LabVIEW Web UI Builder and Data Dashboard
measure angular velocity, angle and actuation using a breakout board gyro sensor, DAQ, and LabView
How to measure angular velocity, angle and actuation using a breakout board gyro sensor, DAQ, and LabView??????
There is a single channel data acquisition code which measures angular velocity, angle and actuation using a breakout board gyro sensor, DAQ, and LabView attached to this, i need a help to creat dual channel data acquisition code ????
(11,563 Views)
Accepted by topic author Adarsh99
Attached you can find a vi that you can use in order to read the angular position measured from an encoder.
If you need more examples about the tasks that you can develop with NI-DAQmx and LabVIEW, you just need to open LabVIEW and click on Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Counter Input.
(11,537 Views)
Thank you very much for your reply for my Question. We are not able to open the code because of lower version i.e 2010 so how to access that code in LabView 2010??????
(11,509 Views)
