LabVIEW Web UI Builder and Data Dashboard
upload CADQ data using daqmx in NI WEB UI BUILDER
i want to get sensor data thru CDAQ in web builder and to create web service to access it in web builder how can i do that . i have build the program but it show zero value in web builder .
My program is attached . kindly help me out
M Waqas
(6,333 Views)
Hi engrwagas,
First, the VI included in the project and the VI in the zip file attached are not the same. Second, I would recommend that you start with a DAQmx example. I would recommend using the the Acq&Graoh Voltage-Int Clk.vi which is found in the Example Finder. To get to this, in a VI go to Help -> Find Examples... Then go to Hardware Input and Output -> DAQmx -> Analog Measurements -> Voltage.
If after fixing your project and using the example, you are still not able to see the values in Web UI Builder, please include a screen/VI of your Web UI code. Sincerely,
Julianne K
Systems Engineer, Embedded Systems
Certified LabVIEW Architect, Certified LabVIEW Embedded Systems Developer
(6,318 Views)
my hardware is ruuning well with this VI which i upload with problem . the VI you suggested has output in waveform data type which is not supported by web builder. and also the issue is that physical channel input when i connect it to connector pane it gives error on bulding web service .
thats why i build a simple VI which gives output in double i have 2 main problem plese help me out on them .
1- physical channel input is not supported in building web service.
2- which input are required to be connected with connector pane using daqmx for web builder.
Further i will tell you in next mail
regards
waqas
(6,306 Views)
In the project you attached, there is no web service. You will need to build your VI into a Web Service in order to access it from Web UI Builder. Please see this document, under the subheading "Deploying your VI as a Web Service", for instructions on how to do this. Sincerely,
Julianne K
(6,296 Views)
