LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Autonomus Maze Solving Robot
I am planning to do a project on maze soving robot using Lego Kits and LabView. Can anyone here guide me on this. I need help on the fesibility of implementing this using these two softwares. Also guide on programming the Mindstorm using LabView. I am a novice to LabView. Any guidance would be of great help.
(8,368 Views)
nidansp,
Well what you're wanting to do can definitely be implemented.  Pointing the light sensor downward at the ground will provide you with different values based on what color the robot is currently sitting on.
As far as developing this system in LabVIEW, you would need LabVIEW and the NXT Toolkit for LabVIEW, available here:
https://www.ni.com/en/support/downloads/software-products/download.lego-mindstorms-module-for-labvie...
If you are unfamiliar with LabVIEW in general, I would highly recommend taking at least the LabVIEW Basics course.  If you're not interested in going that route, you could reference this site, which contains a good (albeit much less comprehensive) overview of the LabVIEW development environment:
https://learn.ni.com/learn/article/labview-tutorial
Let me know if there's anything more specific you're looking to find out!
Peter L.
Peter L.
www.ni.com/support/
(8,341 Views)
I'm very interrested in your project. I'm not a LABView hero but mayby we can help. I'm also working on a project with the NXT and LABView.
What are the problems your facing now??
with kind regards,
Andries
(8,297 Views)
