LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Block for Motor Multiplexer
Hey guys,
I've got to use Labview for Project. I use it for the first time, and anyway I don't know much about this programming.
Usually we would only need Labview to use the direct commands, but as my team needs much more motors than
the 3 you can connect to the nxt, we've got 2 Motor Multiplexer from Mindsensors.com. As there doesn't exits a block
for Labview, we asked them if they've got one, and they sent us the block I attached.
My problem is now, how do I have to use that block? it hasn't got a NXT-Object in/out or an error in/out, and after all
I don't even know what to fill in at motor mux or mode.....
I guess it is a very stupid question which shows that I have no clue ^^ I admit, but I havent got the timeand motivation
to learn building blocks etc..... I need labview this one time and then I don't expect using it very often 😉
So I would be soooooooo glad if someone could tell me how to use that thing ^^
greetings
Message Edited by Sh3itan on 04-29-2009 07:40 AM
(6,483 Views)
(6,479 Views)
sorry, didn't find the edit button o.O
okay, got it, it was a rather stupid question, I "programmed" only in the direct mode before... so I tried it in the other mode, and it worked fine.
So my new question would be now, can I use this block in the direct mode too?
greez
(6,473 Views)
