LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Bluttooth LABVIEW and LEGO
Hi Everyone,
I am studing the LABVIEW bluetooth connectivity and control of LEGO now. I've tried to follow the instruction in the getting started guide for the NXT toolkit. It says to do scan and try and find the NXT.
Labview does not find it.
I can connect to the NXT via the bluetooth directly but even then the labview doesnot show that it is connected. Any ideas?
(But I can connect to the NXT via the bluetooth to on brick,and It was worked well.)
chengyu
 Kudos! Thanks!
(7,460 Views)
This is a common issue.  The easiest solution I have found is to increase the timeout on the VI that you are using to scan for NXT's.  the default timeout seems to be too short.
Ed DeWitt
(7,451 Views)
This article is intended to indicate the installation and configuration process between LabVIEW and educational robot Lego Mindstorms NXT wirelessly, this will enable LabVIEW developers in having a mobile platform for the development of projects and autonomous robots, we need to install some programs the computer:
https://decibel.ni.com/content/docs/DOC-32448
(6,288 Views)
