LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Connecting LEGO mindstorms NXT to my computer
I am trying to learn Labview using the LEGO mindstorms NXT robot. I installed Labview 2009 and started working, but when I open the NXT terminal in the NXT module it claims that the NXT is not connected although it is (via USB). Any ideas ? Could this have to do with the fact that I am using Windows Vista ?
thanks
Message 1 of 10
(13,236 Views)
Please take a look at this older forum post related to the same issue with the same O/S and let me know if this helps.
Best,
Message 2 of 10
(13,230 Views)
Thanks for the help, this seems to be a similar problem, but I troed the solution suggested their (running labview as administrator) and this did not solve the problem. I still get the "not connected" status.
Anyone?
Message 3 of 10
(13,226 Views)
You are welcome. Are you able to see the NXT in Device Manager under 'LEGO devices. If not, try connecting it to a different USB port on your PC and be sure to follow the steps beginning on pg. 4 of the 'Getting Started Manual'.
Regards.
Message 4 of 10
(13,193 Views)
To further address your post, here is a link that lists the system requirements for the NXT. Hope this helps.
Message 5 of 10
(13,184 Views)
Still no success. I can see the lego-device in the decie manager, I followed all instruction and my computer seems to qualify but I still get the not- connected status. I was able to connect in a different computer (that uses windows XP). I have a feeling that this has to do with vista although the specifications say that it should work with vista.
Message 6 of 10
(13,049 Views)
Have you re-booted your computer since the installation? If you have and still get the 'not connected' status, try uninstalling and the LV NXT Module.
Regards.
Message 7 of 10
(13,039 Views)
This article is intended to indicate the installation and configuration process between LabVIEW and educational robot Lego Mindstorms NXT wirelessly, this will enable LabVIEW developers in having a mobile platform for the development of projects and autonomous robots, we need to install some programs the computer:
https://decibel.ni.com/content/docs/DOC-32448
Message 8 of 10
(11,788 Views)
This looks like a duplicate post. I think you will have a better chance of getting an answer here:
Getting results to the Lego mindstorm NXT brick
Sam Burhans
Senior Product Manager
Message 9 of 10
(11,776 Views)
good observation, forum found some cases in which the same answer more than one question answered, is why it is placed in both links, thanks again
Message 10 of 10
(11,770 Views)
