LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Connecting to NXT Brick
I am attempting to "Choose NXT" in LVLM 2010 with the FTC Toolkit already installed.  I have a USB cable running from my host computer to my NXT brick.  My NXT brick is on.  When I click on the pulldown arrow, my only choices are "NXT Target: Unspecified" or "Find NXT..."
A little background:  On this same computer, when I had LVLM 2010 installed WITHOUT the FTC Toolkit, I was able to connect to the NXT fine via the USB cable.  Since installing the FTC Toolkit I have not been able to connect to the NXT at all.
FYI, I have LVLM 2010 installed on another computer (without the FTC Toolkit installed) and I am able to connect through the USB cable to my NXT without a problem.
We have our competition in just over a month.  Please help!
(6,299 Views)
It sounds like your NXT driver installation did not happen correctly.   You can verify that by checking the things listed here:
http://bricxcc.sourceforge.net/NXTFantomDriverHelp.pdf
There are instructions to redo the installation if that is what is needed.
(6,290 Views)
