LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Display unsigned value (battery voltage) = 8134 formatted with a decimal point: 8.134
How can I display an unsigned value such as 8134 with an "implied" decimal point e.g. 8.134 without dividing by 1000? Is there a format code that will do this? I have Student Version 8.2.1. Many thanks
(7,756 Views)
If you just want to display it, you can convert it into a string, separate the first character and the remainder, insert a period after the first character and then insert the remainder of the string.
(7,751 Views)
It seems silly to force such an arbitrary restriction. A division is cheap, why son't you want to do it??? 😮
Of course you could assign a unit such as V and then set the units to kV for the display. 🙂
I would go with the division!
Message Edited by altenbach on 11-18-2007 04:58 PM
(7,745 Views)
Of course, you can also make an Xcontrol.
(7,741 Views)
I doubt that XControls are supported on teh Lego platform Smiley Wink
Ton
My LabVIEW Ideas
(7,737 Views)
LOL, I only saw "I have Student Version 8.2.1" and guessed the post was possibly in the wrong forum. 🙂
(7,734 Views)
