LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Error 1073807300: Insufficient System Resources
When using the direct control mode to read sensor data continuously using USB connection, I get the error:
VISA:  (Hex 0xBFFF003C) Insufficient system resources to perform necessary memory allocation.
After this error occurs, the only way to run the VI again is to restart Labview. Interestingly, the error has not occured when NXT is connected via bluetooth.
The specs are: LabView 2009, Updated NXT 2.0 toolkit, Windows Vista 64.
Please let me know if you have experience with this. Here is a screenshot of a simple VI which causes this error:
Message Edited by Eady on 01-10-2010 03:10 PM
(7,816 Views)
Hello Eady,
the following link will show you the same problem with a GPIB hardware. But the communication protocol in the backround (VISA) is the same and so you will find a solution with the help of the related Links in:
Error Code -1073807300: Insufficient System Resources to Perform Necessary Memory Allocation
http://digital.ni.com/public.nsf/allkb/862567530005F09C8625659A0076B772?OpenDocument
Best wishes,
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(7,761 Views)
