LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
FRC Driver Station Error 7 Help.
We are trying to use falcon 500 motors but we keep getting this error in the driver station:
“ERROR 7 Call Library Function Node in CTRE_Phoenix_MotorControl_Set.vi:5580002->Periodic Tasks.vi->Robot Main.viLabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.”,
We updated our RoboRIO to the newest 2020 image. We also hard deployed and ran code with phoenix onto the RoboRIO. We believe that this was supposed to put the Phoenix API onto the RoboRIO.
If anyone can give us any tips on how to resolve this error, it would be very much appreciated. Also if you have any tips on coding Falcon 500s in LabVIEW
(5,237 Views)
(4,508 Views)
