LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Feedback Node error and NXT
I'm trying to create a simple counter using a LabView 8.5 and the NXT.  I'm using a Feedback Node and it does not show an error while editing the VI.  When I try to download the VI to the NXT I get the following error.
ERROR: An error occurred during parsing.  Node was unable to be parsed. ((Class: FeedbackNode) (VI:Teleop.vi))
List of errors:
When I click on the error it highlights the feedback node (arrow pointing left).
Sean
(6,312 Views)
I found the problem after reading this document:
ftp://ftp.ni.com/evaluation/mindstorms/LabVIEW_for_NXT_Advanced_Programming_Guide.pdf
Feedback nodes are not supported in a while loop.  But, you can convert it to a shift register and it will function.
Sean
(6,309 Views)
