LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
HiTechnic V2 color sensor
Is HiTechnic V2 color sensor on NXT able to trail a strip of LED lights? Would this be possible? If so, how?
(7,827 Views)
There's no straigthforward way to achieve this.
The only way to do this is to use sensor to detect the path color, and if the color start to deviate, then change the direction back to the track.
(7,805 Views)
i have a question regarding that, how do i program the nxt such that it knows wether to deviate back to the right side or left side. For example, it goes off course towards the left and detects a change in color, how do i tell it that it has to turn right instead of left.
(7,800 Views)
You need two sensors.
If one on left start to detect less color, it means it bent to left.
(7,798 Views)
oh no, so this means it is almost impossible to trail a thin strip of LED lights?
(7,795 Views)
Another possibilities, if you turn left, and it get worse, then turn right.
(7,792 Views)
