LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
How can i use a program built on the NXT in LabVIEW
How can i use a program built on the NXT in LabVIEW to control the NXT motors.
(6,052 Views)
I'm not sure what you're asking.  Do you mean a program created from the programming commands on the NXT brick?  If so, I don't think there is anything you can do with it.  Once the program is compiled onto the brick, you can't reverse the process and edit it on your computer.
(6,036 Views)
