LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
How to create exe file ?
Hi
I have written a labview nxt direct commands program. I want to make exe file but every time I try to launch it on the other computer mesage box  error 3  and list off files appears ( for example nxttolkits.vi) I shall mention that I have  enclosed  these files in Dependencies folder  ?!?! I have tried many times with difrent parameters
What can cause this problem ?
Thank you
(6,063 Views)
Martin75 wrote:
Hi
Thank you
Did you install NXT-G or the Fantom driver on the other computer?  In use direct commands, the driver that knows how to speak to the NXT over USB or Bluetooth needs to be installed on the computer.  You can get the latest version of the driver at http://mindstorms.lego.com/Support/Updates/
Joel Sumner
NI-Shanghai
(6,054 Views)
