LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Identical ultrasonic switch blocks behave differently
Environment: NXT-G 2.0
I extended a simple ultrasonic sensor test program, and the switch block stopped working.
I tried removing the extensions to see if I could start from a known baseline and then add program blocks to see what was causing the problem, but after I'd deleted all the extensions the program still didn't behave like the original program.
Explanation of attachments:
bat bot.rbt - the original program which works as expected (moves until sensor reads < 12 inches, then backs and turns)
bat bot 1.rbt - as far as I can tell identical to original program, but the '< 12 inches' branch is never chosen
bat bot speaker.rbt - the intended extension - adds a sensor display loop and uses sound sensor as an additional way to turn
Any help figuring out why bat bot 1 doesn't behave like bat bot would be appreciated.
BTW, might be helpful to add .rbt to the list of valid attachment extensions.
(6,203 Views)
NXT-G is not a National Instruments software environment. As such I am not able to help you with your question. Other people in the community may know, but you would probably be better served finding forums which support the environment you're using.
Good luck!
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(6,189 Views)
I appologize, the following link led me to belive this might be an appropriate forum:
http://forums.ni.com/t5/LabVIEW-for-LEGO-MINDSTORMS-and/Is-this-forum-used-for-mindstorm-nxt-questio...
Certainly there didn't seem to be any relevant activity in the legos forums.
(6,154 Views)
