LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
LabView toolkit with version 8.2.1
I've upgraded to LabView 8.2.1 and now it seems I can't mass compile the NXT Toolkit. As an example, when I open some Vis like the rotation sensor VI, I see it is broken, and has some missing 'property' definitions.
Anyone else had such problems with LabView 8.2.1?
Guy Ziv
NXTasy.org
(7,822 Views)
Hi Guy,
I mass compiled 8.2.1 several weeks ago and noticed it failed around the NXT Toolkit. While I could successfully mass compile the NXT Toolkit folders, I did reproduce the behaviour you are seeing.
I'm going to speak with John to see what recommendations he has on this issue. I'm sure it's something we'd like to look into, so any additional information at your end would be helpful.
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(7,745 Views)
Hi Guy,
After speaking with Brady and John on this issue there appears to be a problem with the deletion of NXT resource files during a mass compile. Apparently force compiling the VIs solves the issue, but this is extremely painful and can't be considered a valid workaround.
Our suggestion: uninstall and reinstall the toolkit, then mass compile for 8.2.1. R&D is looking at this to see what's going on, so I can assure you we're working to resolve the issue for all NXT-related products in the future.
Let me know if you have any further questions/comments/concerns. Cheers.
(7,730 Views)
Could tell how can control LEDS in sppedy with RIDE/VAB, i supose that I have to write in a memory adresss ¿wchich adress? Thanks.
(7,554 Views)
Hi aif -
I think you've posted your question on the wrong board. If you are asking about the NI-Speedy, you should try posting on the LabVIEW forum. This forum is for questions relating to LEGO MINDSTORMS NXT.
James Blair
NI R&D
(7,546 Views)
