LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Labview 2009 Module Mobile And Lego Mindstorms NXT
Hi 😉
I've installed the mobile toolkit in labview 2009 but when I created a new mobile project I didn't find the NXT Programmings category on menu.....
are they not supported?
I would like to control my nxt with my PDA through bluetooth.
Thanks in advance for help
(7,394 Views)
which NXT software did you exacly installed? LabVIEW Module for LEGO MINDSTORMS NXT or LabVIEW Toolkit?
I would like to be sure to have corretcly understood: in a mobile project, the function palette of a VI under a PDA target does not have the NXT palette, correct?
Bye!
Licia
(7,383 Views)
I've installed LabVIEW Module for LEGO MINDSTORMS NXT.
Exactly, in a mobile project, the function palette of a VI under a PDA(Windows Mobile 6.0 Device) target does not have the NXT palette.
(7,379 Views)
thanks for the clarifications.
You have not the palette as NXT LabVIEW Module is not supported on a mobile target, so the PDA module won't work with the toolkit.
Bye!
Licia
(7,376 Views)
Ok, Well.
But I need to send to my nxt robot some bluetooth message from windows mobile.
Probably If i use the bluetooth discovery vi and I find the nxt robot, I can send a message to it.
What do you think?
(7,374 Views)
