LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Lego and DAQ
Hi Jolanta,
That sounds like a good idea. Good luck with your xy table build!
Yes please do post back when you have an update.
Kind Regards,
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
Message 31 of 35
(3,215 Views)
Hello there
I have built assembly which moves my sensor in X-Y direction. I have attached the file which moves the sensor in front-back-left and right direction and acquires the corresponding voltage.
Now I am stuck how to get the 3D scan of an object beong scanned? That is how to get the X,Y and Z co-ordinates of the object being scanned in a dynamic manner.
Message 32 of 35
(3,203 Views)
Something like this might work. You will probably want to change the Daq call to be a single shot aquisition. Then the final output here would be a 2D array of z coordinates
Message 33 of 35
(3,198 Views)
I dont get the output. The array on the front panel remains unchanged.
Message 34 of 35
(3,191 Views)
hello there the array remain unchanged,
Message 35 of 35
(3,176 Views)
