LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Maze solving using image processing using labview
Hello All
I want to capture a snapshot to a maze with the lab view and then I want to analyse this image and process it and solve the maze and send the direction and distance to a lego robot so it can be able to solve the maze on reality, i don't know from where to start or what tools i need so i need your help please?
(8,644 Views)
Do you think it might make sense to start with an easier project?   This sounds a bit complex for your first attempt at programming an NXT robot.
(8,633 Views)
Hello;
You can browse this board for examples which is specifically for NXT and also you could post your questions there.
http://forums.ni.com/t5/LabVIEW-for-LEGO-MINDSTORMS-and/bd-p/460
(8,621 Views)
Hi, i have the same problem right now, can u solved it? can you help me?
(6,394 Views)
