LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
NXT Terminal cannot find vi
back in Jan 2007 there was the posting below - has this been fixed by any chance? I cannot find teh open VI in teh terminal window of pc either (using student 8.0 german version).
P
copy of posting text below:
@Brumma wrote:
Hi Daindim,
I have the same problem with the German version of LabView 8.2. I can't see the VI in my NXT terminal. Is there a nother solution then install an old version?
Bruno
Hi Brumma,
If you have a non localized version of LV - means an english one - it should work.
Daindim
(8,115 Views)
Ok - I did find the patch on the VI site - should have searched a bit longer !
Problem solved, the example code runs nicely.
Thanks to all VI developers who have made this possible.
P
(8,103 Views)
Accepted by topic author pbre
I have the same problem with my german version of LV8.21 and the NXT-Toolkit.
 Could you or anybody else show the link to the mentioned patch.
(7,806 Views)
Sorry hher,
for the life of me I cannot remember the exact link. I have the patch down loaded on disk and the file contains a html readme: Here is
the extract describing its installation
Windows
Complete the following steps to install the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0.1 Patch for Windows.
  1. Download the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0.1 Patch from ni.com/academic/mindstorms.
  2. Unzip the nxttoolkit101patch.zip file and open the directory that corresponds to the LabVIEW version installed on the computer.
  3. Copy the vi.lib directory you downloaded and paste this directory into the labview directory.
  4. In the copy warning dialog box, select Yes to All.
Try searching for this zip file? I must say I could not locate it tonight either on the ni site.
P
(7,796 Views)
PS to hher - there is a message also from member 'engseeo' in this message board with the patch attached as file!
It is under message subject  'compile error'
Good luck!
(7,794 Views)
Thank you.
The patch worked for me.
I saw this patch before, but thougt that it is only for some problems in LV8.5
(7,781 Views)
