LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
NXT case structure
Hey Im making an nxt robot for a competition and it has to go thru two phases for the competition.  Shifting between phase 1 and 2 is controlled by a timer.  the only issue im having is how to setup multiple shift registers for my program
(6,364 Views)
Sorry, I don't have the NXT toolkit installed, but maybe you should move the select node outside the case structure and wire the output to the outer case selector to swrich between Phases 1 and 2.
If you need more shift registers, just add them.
(6,361 Views)
Thanks for the response, I just started labview and this is for a project, i know the shift register transmits data thru diiferent loop iterations but im not sure how to setup a second one to loop info for phase 2.  Once we enter phase 2 we do not return to phase 1.  I dont know how to connect the second shift register to the phase 1/2 case without getting an error
(6,360 Views)
How are you connecting and what kind of error are you getting?
(6,358 Views)
It said we had tunneling errors and selector case value things, but this is the new setup i made after youre suggestions is the format for the shift registers okay?
(6,355 Views)
