LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
NXT terminal : strange behavior
Hi FOLs,
As my NXT terminal doesn't list the VIs that are currently open, I have a few questions:
1. Can this behavior easily be corrected ? (I'm using LV 8.2 French Pro version under Win XP SP2)
2. In addition to the first question, I woud like to know if there is any way to compile VIs into RXE files programmatically so that I could build a friendly use interface to discuss directly with my NXT.
Best regards and have a nice end of year !
Daindim
(7,934 Views)
Hi back FoLs !
And have a good 2007 year !
I solved the issue by using LV 7.1. Then the NXT terminal lists VIs in memory without any trouble.
Daindim
(7,910 Views)
Hi Daindim,
I have the same problem with the German version of LabView 8.2. I can't see the VI in my NXT terminal. Is there a nother solution then install an old version?
Bruno
(7,851 Views)
Hi guys,
sorry for the inconvenience at this point.
Unfortunately only the english LV 8.x version works with the NXT Toolkit.
The problem is known in the interim and will be fixed asap!
BR
ThSa
(7,844 Views)
@Brumma wrote:
Hi Daindim,
Bruno
Hi Brumma,
If you have a non localized version of LV - means an english one - it should work.
Daindim
(7,830 Views)
