LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
PROBLEMS BUILDING AN APPLICATION
I have constructed a small program that establishes a connection with the NXT  during 6 seconds and then  closes it. I ´m working with  Labview 8.5. From Labview it works perfectly. When I construct the application,(standalone application fron the proyect manager) the program does not work. When I press the "CONECT" button nothing happens.
What is the problem?. Why?.
I can contruct other aplications without any problem but if If I include the "vi"s to conect with NXT it does not work.
jokin
(6,579 Views)
Sorry I have omited the picture of the block diagram.
(6,578 Views)
Have you tried the suggestions posted in this thread?
James Blair
NI R&D
(6,547 Views)
I have tried  this thread´s solution and now it works perfectly.
Adding the "NXTToolkit.BluetoothLibraryReferences.vi" to the proyect and includes it in the "dynamic VIs and support files" tab solves the problem.
Thank you very much
(6,541 Views)
