LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Problem with usb connection on Vista
Hi all
I have LV 8.5 instaled on Vista Ultimate 32 bit. I have allso installed the NXT toolkit and the path 1_0_1.
However I have never managed to get a connectin to my NXT hardware. It does not see any NXT device when I open the NXT terminal
I'm running LV as administrator and have VISA 4.2 installed.
Is anyone having the same problems? Are there any solutions?
Thanks, Herbert
(6,522 Views)
You might want to try running Windows Update.  Sometimes it will find & install updated USB drivers for your onboard USB Controller.  If it doesn't I would go to your motherboard or PC manufacturer's website to download & install updated device drivers.  You may also want to update your sound card & video card drivers too.  You might also need a BIOS update.  I doubt it but it couldn't hurt to check to see if one is available.
(6,490 Views)
