LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
.RCD File Foramt
In the Lego NXT software language, there is a "record and playback" function that allows a user to run a program that records the rotations of selected motors, stores the values in a .RCD file, and then play back the recorded sequence. Does anyone know the format of the .RCD file? I'd like to upload it, view it, and possibly edit it, but I can't find a description of the .RCD file format anywhere. I'm guessing that the file format that Lego uses is the same as LabView since it's a derivative of LabView.
Thanks!
Message 1 of 1
(6,331 Views)
