LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Reset motor and precision movement with the NXT tookit
I am having trouble with controlling the motor with the NXT toolkit...
The idea is that the motor gets the command to turn to a specific position, not for a selected amount of degrees..
The motor is attached to a disk divided in 6 compartments. The input comes from the Hitechnic color sensor, and depending on the color the disk should turn to a specific compartment.. But I cant seem to get the reset motor block working, maybe I am interpreting they way it operates wrong..
also, when on fairly high speeds, the motor isn’t very accurate.. since its a servo with feedback, shouldn’t it be able to correct its position if it goes too far?
Message 1 of 9
(9,980 Views)
Here is a screenshot of my current test setup.
Please ignore the mess, I was trying something new.
The light sensor was added in a attempt to stop the wheel from moving at a certain light intensity.
Message Edited by Bramgozer on 05-22-2008 08:33 AM
Message 2 of 9
(9,972 Views)
Bramgozer - I cannot help you, but can you tell me where to get the color sensor VI?  The HiTechnic VIs do not compile-to-brick for me, being password protected.
The reference to "FTC demonstration competition" did not lead to anything.
You mentioned in a previous thread that you asked HiTechnic whether they support the color sensor in LabView -- any reply from them?
- nossr
Message 3 of 9
(9,916 Views)
Yes they sent me an email with the beta blocks for their sensors in labview, please sent me a PM and I'll forward the mail to you 🙂
Message 4 of 9
(9,910 Views)
Bramgozer - Thanks for the reply.  I don't know what a PM is but you can forward the email you mentioned to roger.noss@sbcglobal.net
- nossr
Message 5 of 9
(9,899 Views)
Are you talking about the issue mentioned here?
(Edit for tags.)
Message Edited by DJDDA on 06-11-2008 02:01 PM
Message 6 of 9
(9,850 Views)
sort of... but that didnt every really come to a clear solution.. it just seems odd to me that a high-tech motor like the NXT servo would need that much external control to gain a reasonable amount of precision..
Message 7 of 9
(9,844 Views)
Unfortunately, it would seem that your "clear solution" is not available at this time. The current conclusion, as I understand it, is that the NXT servos cannot be controlled with precision except as part of a program which is stored and executed from within the brick itself. That this conclusion is unpalatable does not invalidate it.
Message 8 of 9
(9,802 Views)
Sorry by my english ...
in fast movements when you turn off the motor they pass the position, I have one projet with the same problem and I correct this including one control in power motor, when the position is near the stop position I down the power level motor, but never "0" with 5 or 10 they stop correctly, if you wish can put more steps and down first to 25 and after to 10 with comparators or but one linear control to power=|endposition-position+1| * 10 and one comparator and if power > 75 then power = 75.
I hope that work.
Now, one deal, can you send the VI to hitechnic color sensor and other VI that you have to hitechnic ?
Message 9 of 9
(8,985 Views)
