LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Unable to Mass Compile
I have LabVIEW  7.1.1 and I installed the LabVIEW Toolkit for LEGO Mindstorms NXT.
I don't have a file called Curr Dir. in the Labview\vi.lib\addons\NXTToolkit forlder.
I also looked for a file called MAX\Assistants\LvdgEN\lV71 . I don't have it eather.
this came from NI's help .
How do you Compile??
What did this old man do wrong.
hal2020
Harold L. Whitmore
Message 1 of 11
(10,087 Views)
You would first navigate to the NXTtoolkit folder, then press [current folder], the button right below the [cancel] button. 🙂
Message 2 of 11
(10,080 Views)
Thanks for replying.
I don't have a [current folder] and no [ cancel] I have looked all over the NXTToolkit folder and it's not their.
I'm thinking that I must have loaded the programs wrong, but I can communicate with the NXT  brick over bluetooth.
I have none of the compile files?
hal2020
Harold L. Whitmore
Message 3 of 11
(10,073 Views)
@hal2020 wrote:
...I have looked all over the NXTToolkit folder and it's not their.
All you need is the NXTtoolkit folder.
  1. Open LabVIEW
  2. Go to menu: "Tools....Advanced...Mass Compile".
  3. The Mass Compile tool will immediately open a file dialog as shown on the image. Browse to the NXTtoolkit folder and press the button in the lower right.
Message Edited by altenbach on 12-30-2006 03:38 PM
Message 4 of 11
(10,070 Views)
Thanks again
I have opened labview and under tools I do not have a  advanced or mass compile to click on.
so without being able to click on advanced I can't get to the screen you have shown me.
My NXTToolkit folder looks just like the one you have. but I can't get to it the way you did.
I am going by the instructions that follows.
Mass Compiling
To run this toolkit efficiently, you must mass compile the toolkit VIs in the version of LabVIEW in which
you installed the toolkit. Complete the following steps to mass compile the LabVIEW Toolkit for LEGO
MINDSTORMS
® NXT.
1.
Launch the version of LabVIEW in which you installed the toolkit.
2.
Select Tools»Advanced»Mass Compile.                __(((THIS IS WHAT I CAN'T FIND?????)))___Tools is their but  no     ADVANCED????
3.
Browse to the labVIEW\vi.lib\addons\NXTToolkit folder and select Curr Dir.
4.
Select Mass Compile to begin the mass compile process.
Note
Mass compiling the toolkit takes around 10 minutes on most computers.
Hope this helps you understand .
Thanks again
hal2020
Harold L. Whitmore
Message 5 of 11
(10,065 Views)
Maybe you should try to repair the LabVIEW installation, who knows what else is missing. :(. Did you originally install everything into its default location? Does LabVIEW work fine otherwise?
Here's my 7.1 menu for your reference:
Message Edited by altenbach on 12-30-2006 04:23 PM
Message 6 of 11
(10,061 Views)
I can't Thank you enough. For that last picture.
I was opening labview all the way to a new vi, but when i went to the first screen the last pic you shoued me I found ADVANCED.
And was able to compile.
meny thanks from an old man that some times suffers from Operator head space.
Thanks again
hal2020
Harold L. Whitmore
Message 7 of 11
(10,056 Views)
'glad it worked out. Now the real fun starts. 🙂
Message 8 of 11
(10,051 Views)
I installed Labview 2011 (have license) on 😧 Dics and install Labview LEGO MINSTORM NXT module from website: http://www.ni.com/white-paper/4435/en (choice Download the toolkit, then register information to download) add-on Labview. Then install completely, I launch Labview and choice Tool -> advanced -> mass compile, I don't find Cirr Dir file. Can you help me? thank you so much. This is a attached picture.
Message 9 of 11
(7,780 Views)
Have a some mistake and I want to add more information. I install Labview from DVD and install full. I choice tool - advanced - mass compile, then 😧 LABVIEW/vi.lib/addons/NXT toolkit. as a result of the same picture which I posted.
Message 10 of 11
(7,779 Views)
