LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Uninstalling Custom Blocks
Can anyone tell me how I uninstall the custom block I imported from Labview?
I can see the block folder under ../lib.vi/LEGO/ but am nervous about just delete it.
Any advice appreciated
boogle
Message 1 of 9
(9,055 Views)
Hi boogle,
i don´t know, but you can simply try it. zip this folder and delete the original.
Hope it helps.
Mike
Message 2 of 9
(9,046 Views)
Thanks for the prompt reply Mike. Removing the folder does the trick. - you don't even need to restart Mindstorms.
Does seem a bit of an oversight not to provide an uninstall option in the user interface.
boogle
Message 3 of 9
(9,042 Views)
I believe you can also remove them through the NXT-G import/export wizard.
Message 4 of 9
(9,038 Views)
That is where you would expect it to be, If it's there, I can't find it.
boogle
Message 5 of 9
(9,033 Views)
In v1.1, go to Tools>Block Import and Export Wizard
Click on Manage
Click on the block
Click on Remove
This may be one of the small changes from v1.0.
Message 6 of 9
(9,010 Views)
Are you referring to the version of Lego Mindstorms NXT or Dynamic Block update?
On the Mindstorms site I can only see v1.0 of Dynamic Block update and no update for Windows PC NXT software.
boogle
Message 7 of 9
(9,008 Views)
Sorry.  I was referring to LEGO Mindstorms NXT-G v 1.1.
Message 8 of 9
(9,000 Views)
Thanks for the information - I found the v1.1 update for sale on the lego site, fortunatley I bought my system after 7th May and so am eligible for a free update!
boogle
Message 9 of 9
(8,987 Views)
