LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Where to download Labview?
Guys, how to download labview?? please help me.. Thanks you!
Message 1 of 11
(9,600 Views)
Hi Weeward,
If you're looking to download a trial of LabVIEW, you can go to the trial page: http://www.ni.com/trylabview/.
Check out more information at http://ni.com/labview.
Jeff | LabVIEW Software Engineer
Message 2 of 11
(9,585 Views)
Thank you for the link jeff.. May I ask if labview is easy to use? because i might do programming using labview for my Lelgo Mindstorm 2.0.
 Thanks you!
Message 3 of 11
(9,575 Views)
Well, that would depend on your previous programming experience :). In general, it's easier than a lot of the text-based stuff.
You'll need the LabVIEW Module for Lego Mindstorms NXT. http://zone.ni.com/devzone/cda/tut/p/id/4435
Message 4 of 11
(9,568 Views)
Thanks againg Jeff.. I would like to ask if it is possible to send a SMS message to a phone using my Lego Mindstorm 2.0. I thnk i am going to use lab view.. it is possible?? thanks
Message 5 of 11
(9,566 Views)
Take a look at this forum as this is a duplicate thread.  I believe it will accomplish what you are trying to do.  Please continue asking questions regarding this issue on this thread.  This is possible, but you need an intermediate step.
Mike S
NI AE
Message 6 of 11
(9,548 Views)
May i ask if there is available Lego Mindstorm toolkit that suits for Labview 9.0?.. Because the toolkit that is available for now is the Lego Mindstorm toolkit for LabVIEW 7.1.x, 8.0, 8.2, 8.5.x, 8.6.x. And I have Labview 9.0.. How can I get a toolkit? Thank you.
Message 7 of 11
(9,531 Views)
If you want to use the Lego Mindstorm APIs, they have moved to the Module instead of the toolkit. In the link provided above, you can install the module for LabVIEW 2009 and you should be good to go.
-Zach
Message 8 of 11
(9,510 Views)
Hello
    What do you mean that I should be goog to go? sorry I cant understand.. 🙂 Thank for the info sir. i had a PDF files about a simple programming in Lego Mindstorm in Labview but in the instruction, it has the toolkit and I cant see it. I only have the module. Like you said they moved it to a module. Thank you.. Sir, may I ask if you can send me a link or instruction on how to program on LABVIEW 2009 for my Lego Mindstorm 2.0? Sorry, this is the first time I encounter LABVIEW.. Thnak you again sir..
Message 9 of 11
(9,505 Views)
Message 10 of 11
(9,498 Views)
