LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
lvproj
Hi All,
I am dusting off my NXT and have just installed the 2009 toolkit and updated FW to 1.28. All ready to go!
One question, is it possible to use the LabVIEW project structure in managing VIs (that are targeted at NXT)?
I am very used to using the .lvproj for normal LV development, so am kind-of hoping you can still do it. Not a huge deal if you can't though.
Anybody know?
(5,932 Views)
Hi nrp,
I've had a look myself and it appears that you can use the project structure to manage VIs, however, when you add the VI to a project the VI is no longer targeted at the NXT. So you can store the VIs in a project for easier management, just you have to re-target the NXT if you want to run it. I haven't tested it with the NXT plugged in so it may behave differently if there is an NXT present.
Kind Regards,
Jas.W
Jason W.
National Instruments UK & Ireland
(5,912 Views)
