LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
multiple NXTs
I don't understand. I use 6 motor control to control 3 robot. Which motor controls unneccesary and have to delete?
Message 11 of 22
(4,442 Views)
these ones are unnecessary and breaking the VI
Message 12 of 22
(4,438 Views)
You say that I can't steering robots this method. If I use one, the robot can run straight.
Can I use the attached method to steering, and will operate my program?
Message 13 of 22
(4,428 Views)
Which LEGO MINDSTORMS brick are those VIs supposed to be running on? You need to wire an NXT/EV3 wire into the first one if you want them to work.
Message 14 of 22
(4,416 Views)
If i understand the problem, I can not use two Motor control one after the other to steering.
Could you tell me if I change motor controls in my program to the attached method can my program work?
This is my thesis, and its very important for me, to work properly.
Message 15 of 22
(4,412 Views)
Sorry if I wasn't clear.
You CAN use two motor controls one after the other to steer.
But if you are using the Specify NXT/EV3 VI, you can't have VIs floating on your block diagram with no NXT/EV3 input.You must wire the NXT/EV3 wire to any VIs which are intended to be run on that NXT/EV3. Otherwise, how will it know which NXT/EV3 to use?
Just delete those two, which aren't necessary for your program anyway, and keep the 6 in the image you sent.
Message 16 of 22
(4,407 Views)
Sorry, I was careless. I scroll my program right and I see what you say. I delete them from my program.
This was the problem? My program can be work for now?
Message 17 of 22
(4,401 Views)
I think it will. Test it out and let me know if you are still experiencing issues.
Message 18 of 22
(4,399 Views)
THANK YOU VERY MUCH ALL YOUR HELP!!!
If it will work you save my life 🙂
Message 19 of 22
(4,397 Views)
Hello garrett8357!
You were right, my program run succefully! Thank you very much your help!
I have a small problem. When I run the program I get changing delay (0-1sec), after I give a command.
I read about this problem from your webpage:
http://zone.ni.com/reference/en-XX/help/372962A-01/lvnxt/directmode/
Note:  Timing of loops in Direct mode is not always perfect.
Have you any idea how can I get constant delay or a synchronization method?
Message 20 of 22
(4,383 Views)
