LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
nxt toolkit - where are the tools?
i have Labview 2011 and Installed LV2011NXT Toolkit.
After the patch:
The Tabs are available under "NXT Toolkit"
But no one Block... Nothing there.
 Is my Version not current?
I hope someone have a Idea.
(6,587 Views)
which version of the NXP-Toolkit are you using?
Following this link there are only versions availabl compatible up to LV 2011:
LabVIEW Add-ons for LEGO® MINDSTORMS® NXT
http://www.ni.com/white-paper/4435/en/
Or am I wrong?
Michael
(6,563 Views)
Hi Weltensegler,
Just a little background info... From LV 8.6 to LV 2009, we took the NXT Toolkit and made it the NXT Module. By doing this it now takes on a yearly release cycle and is tied to a particular version LabVIEW (i.e. NXT Module 2009, NXT Module 2010, NXT Module 2011, etc.). The last NXT Toolkit (v 2.0) only supports up to LV 8.6.
In your case, since you have LV 2011, you'll need to install NXT Module 2011 which you can get from here:
http://joule.ni.com/nidu/cds/view/p/id/2637/lang/en
From your screenshot, it looks like you already have it installed. I believe the VIs you are looking for are under the NXT Robotics palette (right above the Addons palette in your screenshot).
Hope this helps! If you have any questions, feel free to post back.
- Aaron
(6,555 Views)
Thanks, the Problem is solved. The Bricks are in other section.
Thanks for your ideas 🙂 Thanks!
(6,540 Views)
