Как вывести данные из текстового файла на график?
Снимаю с датчиками, 5 секунд и заношу эти данные в текстовом файле, затем пытаются получить их текстового файла, чтобы проверить его на оси Х (он так и выводится), а измерение измеренных значений датчика выводился бы на ось У (он не выводится, вместо него какие то странные цифры). Для проверки значений графика вывожу на экран и массива с параметрами, картинку прилагаю.
(6,035 Views)
Hi Verter,
when you post your question in the English LabVIEW board you should try to use English for your text - cyrillic letters are hard to read for most of the people here. (I can read them, but don't understand most of the Russian text. Thanks to Google for their online translator…)
It also helps to use standard ASCII chars for all filenames, some programs can have problems with your Unicode-based ones…
Beside all this you should simplify your VI to this:
For more help you should also attach your data file (or a simplified version of it) for debugging…
(5,988 Views)
Thank you very much for the answer, I wrote earlier in your forum in English, which translates online translator, but after such translation the meaning of the phrase is lost and the answers came very strange and not at all the ones that were needed. Until now, it remains a mystery to me why on your site there is no Russian version of the site, because we buy programs from you and equipment no less than any other country whose language is on your forum. But in any case, many thanks to you for answering the question.
(5,948 Views)
Hi verter,
Well, GoogleTranslate is quite good for translations from/to English in my experience…
No, can't find any of your former posts…
This is not "my" site. And you don't buy software from "me".
I'm a user of this forum as you are!
(There also is no German subforum here at NI.com, but we have our "own" www.labvieforum.de. Btw. there also is a Russian forum here!)
Glad I could help you!
(5,939 Views)
Good evening, thank you for your reply. You literally answer my questions.
Therefore, I will explain some points of my previous letter, that there would be no misunderstanding
You did not find my previous questions, because this is a new login, I abruptly go to this forum and I do not remember the old login. so it's easier to create a new one than to look for the old one, but if for you it's fundamentally something I can look for.
Of course I know that this is not exactly yours, I figured figuratively that it would be faster to convey the meaning of the phrase on the topic of the issue, rather than delve into details that do not matter who created this site and forum.
And of course I do not buy software from you, and even from a developer firm I do not buy the program personally, for me it will be expensive. Of course, the program is bought by my organization, where I work.
I also know that you have a website www.labvieforum.de. It also exists in Russian and I am also registered there. The problem is that you do not understand this, because in my organization this site is blocked, for safety reasons, since the enterprise is not only a civilian activity. Therefore, I sometimes have to write to this forum, although I repeat once again that every time problems arise with obtaining an answer.
While I was trying to get on this forum, I have already found an answer in other sources of information, and this is your letter with very strange answers highlighted in red. That there was an unpleasant sludge, then communication was with the schoolboy, and not with the engineer, or who are you by profession if not secret?
I'm sorry that I doubted your professional experience, but your answers seemed very strange to me, that this is not yours, and that I did not buy programs from you. I will try even less to handle questions on this site.
Wish you luck!
(5,926 Views)
